Southern California Area Southern California Members.
Looking for a 350TPI and installer
Old Feb 10, 2010 | 11:25 AM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
My 305 TPI is about due for a rebuild, but I'm looking for someone who has a rebuilt 350 and possibly could do the swap for me. I can do it, but don't really have the time to. Any takers or leads?
Old Feb 12, 2010 | 09:05 PM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
Re: Looking for a 350TPI and installer
I can install it for you just PM me for details. As for the actual engine, I don't have a 350, but a 305 bare bones block, but you could search craigslist. Found mine there and I just rebuilt it. I also can rebuild engines for you to. If not and you want me to I can search for you as well. I have the old 305 block that can be made into a 350...if you want. Like I said just PM me.
Old Feb 13, 2010 | 08:51 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I have to cry foul here....
There is no way to make a 305 into a 350.
Old Feb 13, 2010 | 09:43 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I was wondering how it would take to get that myth straightened out.
Old Feb 13, 2010 | 09:48 AM
z28 TPI's Avatar
My apologies you are right Dyno Don please forget what I had said. 89******bird (Sorry I was trying to use your name here) I apologize if I mislead you.
Last edited by z28 TPI; Feb 13, 2010 at 09:49 AM. Reason: I was trying to write the OP's full name
Old Feb 14, 2010 | 08:58 AM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Well, I suppose if someone really wanted to spend the money, a 305 block could be sleeved and stroked out to a 350, right?
Old Feb 14, 2010 | 11:31 AM
Dyno Don's Avatar
Well, when you consider everything has been thinwall casted since 1970 and the bore on a 305 is 3.736 that would mean cutting a 1/4" out leaving no room for a sleeve and can you imagine the loss of strength and the over heating problem.
Stroking is a nother thing, but picture the cost.......completely absurd!
BTW Dave, I now have a 350 that could be rebuilt and installed by me.
Your car is TPI now isn't it?
EDIT: Typo corrected
Old Feb 14, 2010 | 01:38 PM
JERRYWHO's Avatar
the bore on a 305 is 3.376
Don the bore size is 3.736 on a third gen 305.
And yes you can build a 305 block to 356 CID. Just use a 30 over block and a 4 inch stroke crank.
Jerry
Old Feb 14, 2010 | 02:18 PM
Dyno Don's Avatar
Jerry
And you can tell us WHY?????
Old Feb 14, 2010 | 03:12 PM
JERRYWHO's Avatar
Maybe if your an old truck driver and have the need for that 500 to 2,500 rpm power band or your trying for the lowest reving 350.
Jerry
Old Feb 14, 2010 | 06:13 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Me first Don.
Old Feb 22, 2010 | 11:40 PM
streetworkxs's Avatar
can I steal the accesory brackets off the front of the motor? how much shipped to san diego, ca 92129. I need the bracket that houses the alternator, and the other bracket on the passenger side that holds the smog pump and etc.
Old Feb 23, 2010 | 10:02 AM
Dyno Don's Avatar
Long block only.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
