Need a new clutch
Car: 92 RS
Engine: 5.slow
Transmission: 5speed
Need a new clutch
Hey everybody,I want to replace my clutch and I want a performance clutch and flywheel but Im not sure where to get it from.I on sort of a tight budget and cant afford more than about 300.Is this feasable?
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: Need a new clutch
Centerforce Dual Friction for about $280. Team-C Performance on Lakewood Bl. just a block and 1/2 north of the 91fwy. Give them a call.
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Summit shows $280 for the centerforce
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Centerforce sucks and their weight system is a gimmick. Check with Dyno Don and have him get you a McLeod. Its a much better setup and they're local in Placentia.
