Southern California Area Southern California Members.
Higher stall and 3.73's Cali legal?
Old Jul 29, 2010 | 03:26 PM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
So the plans I have for the car include a higher stall for my built 700r4 and of course 3.73's, but are these mods smog legal? How's the MPG with a higher stall?
Old Jul 29, 2010 | 03:42 PM
Stephen's Avatar
Car: 87 GTA
Re: Higher stall and 3.73's Cali legal?
How would tranny or axle mods effect an engine's smog output, to start with?
Other than a resulting different RPM at a given MPH, I don't see how it could affect smog. And since the tests (at least...here in Texas) are RPM based & not MPH based, I don't see any problems.
Old Jul 29, 2010 | 06:13 PM
[quote=Stephen;4625437]How would tranny or axle mods effect an engine's smog output, to start with?
You'd be surprised at what C.A.R.B does not allow in our cars. I do live in California, after all.
Old Jul 29, 2010 | 06:22 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
cali is a train wreck when it comes to emissions...of course you can always find a freind to do it for you but...my dad has a high stall on his 98 t/a but idk about gas milage..
Old Jul 29, 2010 | 06:26 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
You will be fine. There is no way that would effect emissions bro. Stall away!
Old Jul 29, 2010 | 06:29 PM
Stephen's Avatar
Car: 87 GTA
[QUOTE=camaromike222;4625645]
But like I asked.....How would it effect the output? How could they possibly even know those things had been touched? I don't see how, without running VINs, check GM build RPOs on that specific VIN & crosschecking, after actually checking those things which would require a lot more than a smog check could reveal.
That is my point....HOW WOULD THEY EVEN KNOW?
Old Jul 29, 2010 | 06:35 PM
Same for 3.73's? I had them before, but opted for MPG while I put together the LT1 in my garage.
Old Jul 29, 2010 | 06:38 PM
87tpiz28's Avatar
Car: 1987 z28
Engine: 305tpi
Axle/Gears: 2.73 posi
youll be fine. remember a higher stall doesnt mean you need to hit that RPM to move. so when they do the test (its a lighter load then driving) the rpms will be fine. even then it wont effect smog in any way. you saw how my car drove with a 2600 stall, its more noticeable under load/ going up hills at at WOT when it flashes at 3k
Old Jul 29, 2010 | 06:41 PM
87tpiz28's Avatar
Car: 1987 z28
Engine: 305tpi
as for gas mileage, after you swapped in my 342's i went from mixed 16-18mpg to over 25mpg. stalls keep you in the power band= better fuel. dont forget to get a lock up to keep the cruising speed rpm tolerable. also keep in mind those meaty tires you have waiting are a bit taller so that will also bring down your rpms
Old Jul 29, 2010 | 07:59 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Once again you are lacking knowledge in a topic. The test in California is mph based as it is done on a dyno at 15 and 25 mph, hence, a change in torque converter and rear gearing could conceivably alter sniffer test results.
And while the practical application of the law leaves things like that alone, if they wanted to apply the letter of the law, I'm sure some bureaucrat at the CARB could construe things that are written to make mods like that illegal. You are technically changing the car from the configuration that earned its federal emissions compliance which is a far more in depth series of tests than is reproduced by any of the annual or bi annual tests at the state level.
But to answer the O.P. question, no, the practical application of the law does not concern itself with torque converters or rear end gears.
Old Jul 29, 2010 | 08:11 PM
Stephen's Avatar
Car: 87 GTA
You REALLY need to learn some tact
I also posted with QUESTION MARKS, as to how it could possibly affect the results.
Old Jul 29, 2010 | 10:47 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
It has not been a problem with the cars we have taken to get smogged.
Old Jul 29, 2010 | 11:05 PM
Thanks for all the info guys. It is inevitable that I swap my LT1 into my car along with the gears and stall. I have just always been curious. I also needed to know so I can take it to the "right" smog guy. I plan on going with an Lloyd Eliot cam, full exhaust, ported heads and all the bolt on goodies for the engine.
Old Jul 29, 2010 | 11:10 PM
I do remember getting 17-19 hwy when I installed the 3.73's. As for the tires, they are the BFG KD 315/35/17. The ones I have now are 275/40/17. If anything the meats will be slightly shorter.
Old Jul 29, 2010 | 11:52 PM
captain_camaro's Avatar
Car: 1989 camaro Rs or iroc clone??
Engine: 5.oh tpi
Transmission: borg warner t5 world class
Axle/Gears: 3.23-GU5
back then i had 323's(still do) as well a 3200 converter and a shift kit on my 700r4..(Which is now on my 70 caprice)...passed smog fine...sooooo i guess ur good!!!
Old Aug 2, 2010 | 03:34 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Swapping an LT1 into your car WILL require going to the referee and having it recertified. Even though its more work, I suggest putting a stock LT1 in first and then going to the referee. The smog referee will go over the engine with a fine-toothed comb and ANYTHING that is out of place will trigger a red flag. Don just took an El Camino with a TPI conversion to a ref for a recertify from carb to TPI, and the ref failed it because it had a 3-wire heated O2 sensor instead of a 1-wire one. Once you pass the recertify process, then you're free to put any CARB legal mods on it you want.
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
mfp189
Sep 27, 2015 09:25 AM
JSDaddy189
Sep 26, 2015 03:50 PM
