Southern California Area Southern California Members.
can i go lower?
Old Aug 7, 2010 | 07:54 PM
cintegra2003's Avatar
Car: 85 z28
Transmission: auto
can i go lower?
i just lowered my car 2" and was wondering if its possible to go lower or will it be a rough ride.....i have eibach springs now....any one lowered their car more then 2"?or post any pics of a car thats lower then mine....thanks guysName:  2010-06-27201328411.jpg
Size:  158.6 KBName:  2010-06-27201349311.jpg
Old Aug 7, 2010 | 10:23 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: can i go lower?
Yeah, you can go lower, but why.It'll just scrape everywhere & the lower you go the harder the ride.Otherwise your car will bottom out over the slightest bump/dip on the road.
Old Aug 7, 2010 | 11:12 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: can i go lower?
you can go lower, but you have to take into account how low your y pipe will be, also the ride quality will depend on what shock you run and profile tire you are using, if you ask me you car has a great stance as is
Old Aug 7, 2010 | 11:22 PM
89 TA's Avatar
Car: Trans Am/Kenworth
Engine: 383/435 Cat
Transmission: T5/10 speed
Re: can i go lower?
if you do any kind of racing, I wouldnt go any lower. If all you are looking for is a certain "look" since you dont have too much clearance you might as well bag it.
Old Aug 8, 2010 | 05:57 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
Re: can i go lower?
go with bigger wheels if you want to fill in the gap in the wheel wells for that lower look
Old Aug 8, 2010 | 07:50 PM
godreject's Avatar
Re: can i go lower?
bigger wheels also mean less side wall which means rougher ride, you just have to find your median between overall physical appearance vs ride quality
Old Aug 8, 2010 | 08:25 PM
Stephen's Avatar
Car: 87 GTA
Re: can i go lower?
What are your ride heights? Can't just say "lowered 2" as a general number, since different 3rd gen models have different springs & different ride heights.
Here is mine on 17" Snypers/Ground Control Weight Jacks. I'm at 25" front/26" rear.
Old Aug 8, 2010 | 09:09 PM
Car: 85 z28
Transmission: auto
Re: can i go lower?
thanks guys ....i think im gona leave it as is and maybe sell my wheels and get 18" wheels....
Old Aug 8, 2010 | 11:35 PM
mh82camaro's Avatar
Car: 82 camaro berlinetta (z28clone)
Engine: gmpp 350,edelbrock,msd,k&n
Transmission: stage 2 maddog 700r4
Axle/Gears: motive gear 4.10/ eaton posi
Re: can i go lower?
dude i think it looks fine....there right...you would drag your exhaust pipes and/or tips if you have them...i do already....
i have eibach sportlines on mine
Old Aug 9, 2010 | 09:58 AM
irocdan's Avatar
Car: 88 Iroc vert
Re: can i go lower?
mine are 18's.
Old Aug 10, 2010 | 03:14 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: can i go lower?
Based on your pics, it looks like you can still easily get a floor jack under the front end. Are you sure it actually dropped 2"?
I have Jamex springs on my GTA, rated to lower the car 1.5". In reality, it is probably closer to 2".
I can't get a floor jack under the front of my car without first driving it up on blocks. The stance is closer to Stephen's car as shown in his pic.
Old Aug 10, 2010 | 05:28 PM
irocdan's Avatar
Car: 88 Iroc vert
Re: can i go lower?
i too have the jamex springs like brett and i can't fit a jack under mine either.i use a little scissor jack or a 2x4 piece of wood to drive on.
Old Aug 10, 2010 | 06:05 PM
supermariobros's Avatar
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
Axle/Gears: 3.73 posi locker ls1 discs
Re: can i go lower?
I have eibach sportline one my car and it took a few months for mine to settle completely but I think its a good balance between looks and function.
Old Sep 2, 2010 | 11:12 PM
Car: 85 z28
Transmission: auto
Re: can i go lower?
yea i got 2" lowering springs from eibachs
Old Sep 2, 2010 | 11:14 PM
Car: 85 z28
Transmission: auto
Re: can i go lower?
BretD 88GTA do you have pics of ur car?
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
92projectcamaro
Sep 29, 2015 07:07 PM
