fs; mild cam
Car: 1989 camaro Rs or iroc clone??
Engine: 5.oh tpi
Transmission: borg warner t5 world class
Axle/Gears: 3.23-GU5
fs; mild cam
from my camaro(1989)
only used for about 5k miles..
1200-5500 rpm
$60
1200-5500 rpm
$60
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
Engine: 5.oh tpi
Engine: 5.oh tpi
Re: fs; mild cam
i have the spec sheet....idk if the part number is there... n its a crane cam..i think theyre out of business if im correct but ill check n see once i get home today
Engine: 5.oh tpi
Re: fs; mild cam
yes it is..camaro engines(5.0) from 87 up...i got a voodoo which was from 78?to 86..and summit says 78-98 5.0...kinda pist when i found out the truth lol i got a new one from comp cams..much lower than this one, 1000 to 5500 rpm cost me $300 cam only
Engine: 5.oh tpi
Re: fs; mild cam
sounds sick with the tpi...loved the sound when i converted to tpi... pulls SICK too go on youtube look up my account "DINDINTS" n its a vid called 1989 camaro rs v6(lol) its me haulin with that cam when i had the conversion like 3days fresh (^.^)(305tpi)
Engine: 5.oh tpi
Re: fs; mild cam
in the spec sheet it says
1987-1989 chev. 5.0
i may be wrong and it might fit a 5.7 but i just dont want to end up cheating anyone u know?
1987-1989 chev. 5.0
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Re: fs; mild cam
How hard is it to install a cam? Never doen it before. Is it a big process?
Also could you still pass smog with this cam?
Thanks. Tony.
Thanks. Tony.
Engine: 5.oh tpi
Re: fs; mild cam
its actually pretty simple if you know what youre doing..like adjusting the valves removing n reinstalling the intake manifold etc. kinda like a 2 hour job...
YES I PASSED SMOG WITH THIS CAM...this was in 08 i was told i barely passed tho i was idling at 700rpm instead of 1200 like its required...this cam also requires an adjustable fuel pressure regulator..i didnt have one when i smogged n it ran fine..when i did the tpi conversion i put one in n yess its bad *** with that cam ..i only used the regulator for like 3 runs..i removed it kuz i kinda dont know how to adjust it lol!! tpi requires 47-53 fuel psi?? i had it at 91 LOL!!!! it ran sick tho! (^.^)
Engine: 3.0L 2JZGE
Re: fs; mild cam
Tony.
