Passed Smog Yesterday
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
It didn't pass the first time. The HC's and the CO's were just a tiny bit too high at 25mph. Went to Autozone and bought some Lucas Octane Booster $10. Went back 25 minutes later and it passed. Don't have to worry about this for another 2 years.
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Re: Passed Smog Yesterday
That's a nice tip for passing smog. Wouldn't it be nice to have a sticky on the forum with all those "how to pass smog" tricks, since this seems to be a constant area of concern?
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Passing smog is always good news. I take it you have "your" transmission back in the car?
Car: 89 camaro RS, 90 camaro
Engine: 355 TPI, 305
Transmission: 700R4, 700R4
Congrats. I took mine in September and it failed twice. It failed by 1 point due to the HC's at 25mph. Im having an overheating problem that it requires the AC to be on at all times if not it will overheat badly. So I got a 30 day extension which I gotta take it this week again to see if it passes.
Tony
Tony
Do what I did in post 1 and you will be alright. Oh and run Super unleaded gas and let the engine heat up to 220.
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Do you think mine has a chance of passing with those tricks you mentioed vincent?
220,000 305 TBI
No real problems, just an old engine.
I have Hooker 2055's, will this cause it to fail the visual inspection?
220,000 305 TBI
My '85 TA TPI failed and I had to get a new cat, which now has to be a very expensive one with state "approved" serial # on it, and I then passed. The reduced allowed emissions from last April are a bitch. Ah, Kalifornia.
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
Tony
Tony
I don't believe it would be that difficult to pass if thats all you need. I mean, I also own an 82 Regal that needed a cat to pass an it did wit flying colors. Just cost 200 for part an installation. Personally, it is whut it is....
O ok Im gonna take it again this week since the extension will end this week. Ima give it a shot and see what happens if not I will need another extension again its $50 for 30 days dammit o well. But Ima take it wednesday since I run 91 octane u think I should run unleaded for til wednesday til I smog it or will I be ok if i just fill it up the same day I smog it with unleaded.
Tony
Hey Adrian I know am working on it bro.
Tony
Just put some in the same day and the Lucas Octane Boost.
