Southern California Area Southern California Members.
need a tip
Old Feb 13, 2011 | 02:40 PM
captain_camaro's Avatar
Car: 1989 camaro Rs or iroc clone??
Engine: 5.oh tpi
Transmission: borg warner t5 world class
Axle/Gears: 3.23-GU5
need a tip
As most of you may know, I've converted to tpi and have been learning the how good at the same time...well I've got everything going..Dyno don helped me out on my" what i need" and jerrywho came by checked out all my connections and so far everything needed has been plugged in and working properly as if it were fa tory...now here is my problem
I turn the car on and if i rev it, it revs smooth no pops no missfire...but it does not stay on...if i get it to stay on its cool etc. But when i turn it off n sits for a few hours or till the next day, it does it again turns on smooth but dies...
timing? Vaccum?
please help
Thanks for ur time fellas
Old Feb 13, 2011 | 02:41 PM
Engine: 5.oh tpi
Re: need a tip
*how to
Old Feb 13, 2011 | 03:33 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: need a tip
timing? Vaccum?
please help
I'm thinking fuel, fuel pump, fuel pressure regulator, fuel filter, maybe even injectors. Or maybe this; https://www.thirdgen.org/open-loop-closed-loop
Old Feb 14, 2011 | 12:01 AM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Re: need a tip
How long does the engine run before it dies? I'd monitor the fuel pressure, then check all the basics, just like a tuneup, plus verify the sensors are calibrated correctly.
Old Feb 14, 2011 | 12:06 AM
Engine: 5.oh tpi
Re: need a tip
Well it dies as soon as i turn it on but if i give it gas it will stay on of course...but i am going to check out the fuel pressure and the sensors are calibrated...im kinda leaning towards taking it to a tpi tech..we've been pm'img(if that's a word lol) and i think ima go that way im getting tired of the guessing game..
Old Feb 14, 2011 | 12:22 AM
jessc50's Avatar
Car: 88 supercharge Iroc Z,
Re: need a tip
i had a similar problem mine was the bad maf when i would disconnect it would stay on but if i plugged it in it would die
jrdturbo
Mar 31, 2016 02:58 PM
Thaney9
Oct 15, 2015 06:37 AM
Night rider327
Sep 25, 2015 04:47 AM
