Southern California Area Southern California Members.
More mods, another autocross
Old Dec 15, 2013 | 10:43 PM
B4CHawk's Avatar
Car: 2004 Mazda RX-8
Engine: 1.3l Renesis
Axle/Gears: \
http://www.youtube.com/watch?v=q-Fon...ature=youtu.be
Ran the car again; I'm a convicted cone killer after today!
That was one of my faster runs, I feel I could have run faster but my general health isn't too good this week, I did the best I could. Updates to the car are:
Ground Control WJ
1100/lb front springs
235/lb rear
-1.5 camber, 4.5 caster, 0.1 toe out
Koni Yellows (rear set to 0, front full firm)
36mm/23mm sway bars (getting a 18mm/21mm bar for tuning)
GC Panhard bar
Lowered the panhard 2 inches, leveled it out
LCARBS.
Old Dec 16, 2013 | 03:13 AM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: More mods, another autocross
how do you like the weight jacks. 1100lbs front seem firm, hows the ride/handing. considering the weight jacks but im not convinced yet.
Old Dec 16, 2013 | 07:58 AM
B4CHawk's Avatar
Axle/Gears: \
They're great; admittedly, I probably will never adjust the height. The spring rate is pretty firm... but not that bad.
Old Dec 16, 2013 | 11:19 AM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
What tires are you running? What was your time? You mentioned you lowered the panhard bar; was this done using the jegster bracket?
Old Dec 16, 2013 | 11:31 AM
B4CHawk's Avatar
Axle/Gears: \
Jegster bracket and panhard relocation bracket from Founder's.
I'm running Toyo Proxes R1Rs.
My fastest times of the day 50.15. I couldn't get out of that field. Quick, but not as quick as I'd like. Slow for the day was 52> and fast was <48 so I was right in the middle.
Old Dec 16, 2013 | 11:56 AM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Transmission: W/C T5
Um... Never got my invite? The previous link you supplied only an upcoming event for January? Whatever...
You're definitely headed in the right direction with the mods...
My springs were rated at 1000lbs out of the box so after trimming for desired ride height, the rate is a tad bit higher. Definitely not the most comfortable but definitely streetable.
Alignment specs are conservative IMO but if its working and your happy with how the car is responding then rock on.
Panhard business, all good in the hood.
Rear sway bar... Move the mounting brackets on the axle tubes inboard. It will have the effect of a smaller bar. It
Based on your run, your throttle modulation and steering inputs are hesitant and choppy. Totally in line with dialing in a new set up. As you get more confident with the new set up it will smooth out.
The roof mounted camera is great if your looking for something to give you a little sensation of speed. However, you really need to have someone capture the car from a distance so you can see the whole articulation picture. Again, just an opinion.
All in all the car appears to be coming along nicely, well done you. Now I'm actually looking forward to a little WTW action with you.
Old Dec 16, 2013 | 10:57 PM
CA B4C's Avatar
Dude, all of Goose's comments are valid, and worthy of serious consideration. Next time out think about mounting the camera on the side of your car to pick up on the front or rear tire. This will allow you to evaluate tire roll and confirm your tire pressures and/or suspension travel geometry. Another option would be inside the car to eval how you are physically handling the driving aspect. Autocross is more about the driver than the car. The next weak link will be your posi unit. Too stiff a rear bar willl start to lift the inside rear tire on the tight turns and quick transistions, sounds like you have a plan in place. We've discussed posi options. Look forward to seeing you in January, maybe I can hitch a ride ?
Old Dec 16, 2013 | 10:59 PM
B4CHawk's Avatar
Axle/Gears: \
I totally agree with him... at this point I think 95% of my improvements will be in working on my driving style.
Old Dec 17, 2013 | 06:49 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
did you take any tire temps after your runs to check for tire pressures and alignment?
I'd max the castor out as much as you can get.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
