Barely passed smog - high HC advise
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
Kindof amazing, at the exact limit on the two numbers.
From what I read its unburned fuel, any advise based on the other numbers the most probably cause?
It does smell gassy and the mileage sucks (~11mpg). Otherwise it seems to run fine.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Barely passed smog - high HC advise
Sometimes it's arcing inside the cap, replace the cap and rotor.
Car: 1983 Pontiac Trans Am
Engine: 5.0 Crossfire Injection
Transmission: 700 4R
Axle/Gears: 4.10
Check your fuel pressure and tps setting.
Your % co2 should be closer to 15.1
Axle/Gears: 4.10
Check your fuel pressure and your tps setting.
I think you are to rich.
