FS: AFR 195s, Forged pistons, crank
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
AFR 195 heads, 75cc chambers. Pre-Eliminator version with 2.02 intake valve. Has new (1k miles) Manley 22407 springs, 135lb seat - 385lb open. Heads had full 3 angle valve job done last year (1k miles)
(PM me with offer, shipping is around $70)
Icon Forged IC9333 pistons +6cc dome, great condition. Pistons and rods were weight matched. Comes with pressed in stock rods. Minor pits on bottom side due to piece of windage tray found in the oil pan. All cylinders had less than 3% on leakdown test, you could probably re-use the rings. 10.2:1 compression with 75cc heads (PM me with offer)
Stock crankshaft, pristine condition. Was balanced/polished 2k miles ago. Bearings looked new when removed. $50, pickup only
