Southern California Area Southern California Members.
Strange TPS issue
Old 12-28-2016, 01:18 PM
Gr89RS's Avatar
Car: '02 Z06
Strange TPS issue
Hello all, I posted this in the TPI forum as well but also will post here since we have alot of really knowledgeable guys here.
I have an '89 Iroc with 305 tpi. The rpms will dip real low or car will die when coming to a stop or making a low speed turn. Also occasional hesitation with throttle.
The battery, alternator, connections, and all grounds have been checked and tested good.
I went to test the TPS thinking that could be bad.. but on all three prongs I get ZERO voltage with the voltmeter.
Method of testing, connect negative lead of voltmeter to ground on car body. Positive lead goes to the center prong on the TPS.. Ignition in the "RUN" position. NO voltage at all on the center prong of TPS or any its prongs for that matter.
No check engine light which I thought was strange.. I figured if the TPS was bad the light would come on.
What do you think guys.. do I replace the TPS?
Old 12-29-2016, 10:36 AM
Gr89RS's Avatar
Car: '02 Z06
Re: Strange TPS issue
False alarm.. I recently bought the car and yesterday was the first time getting it back on the road and actually driving it.
Turns out it was out of gas -_-. Gauge said I had around a half a tank
Gr89RS
12-29-2016 10:37 AM
Quick Reply: Strange TPS issue
