Southern California Area Southern California Members.
Alignment shop in SFV needed
Old Jan 11, 2002 | 02:54 PM
NickS's Avatar
Does anyone have any recommendations for an alignment shop in the SFV, Simi. Thousand Oaks area? My usual alignment guy is in the SouthBay and I don't have the time to get the car over there before the next time I hit the track. I need somewhere that'll do the car to my specs without any issues or
complaints..
Thanks!
Nick
92 Camaro (Some assembly still required)
Old Jan 11, 2002 | 04:04 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Nick,
There's the shop in Chatsworth I told you about. I think it's Ron's Wheel Alignment or something similar. I can dig up my old receipt if need be.
They had no problem setting up my car to my requested specs.
Old Jan 11, 2002 | 04:08 PM
NickS's Avatar
If you could do that it would be great, thanks. I couldn't remember the name off the top of my head (My memory seems to be getting worse as time goes on... heh)
- Nick
Camaro. Some assembly required.
Old Jan 14, 2002 | 02:27 PM
NickS's Avatar
Thanks for the info Brett. I'm hauling the car up to Ron's on Wed morning. They said absolutely no problem doing the alignment to my specs.
Now I just have to do the math to convert toe out in inches to degrees.
- Nick
Old Jan 14, 2002 | 03:05 PM
bluethunder28's Avatar
Hey Nick,
What are you setting your specs too? Let me know when you figure out the math. I would like to know an easy way to figure it out since math is not my strong point
Glenn
Old Jan 14, 2002 | 03:28 PM
NickS's Avatar
I'm going with -3 to -3.5 camber, +5 to +6 caster and about 1/16th to 1/8th toe out. I'm going to be taking some tire temps at Buttonwillow on Friday to help me confirm the setup.
- Nick
Old Jan 15, 2002 | 01:06 AM
Nick,
I have a "home made" toe gauge which works really well. In Kansas, I made a adjustment to straighten the steering wheel and forgot how turns I did. I didn't have my gauge with me and ended up at a shop and they did it in degrees
Glenn
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
