Southern California Area Southern California Members.
Code 42 problem solved!
Old Jan 21, 2002 | 10:12 PM
BLWR PWR's Avatar
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
Seems like I finally fixed my code 42. After replacing the ignition module and checking all the wires for loose connections with no results I checked into the ecm. Chiltons said that a "faulty ecm could also be the culprit. Dwaynes car is out of action for awhile so he loaned me his computer for awhile. After many, many starts and restarts I am happy to say it did not set the code. I went and bought a new ecm today. It works great. No code 42. I still hold my breath and knock on wood before firing it up though. I'll keep you posted. Jeff K. P.S. Many thanks to Dwayne!!!!!
Old Jan 21, 2002 | 11:12 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Woohoo! Congrats Jeff! I hope thats the problem and you've fixed it for good.
Old Jan 22, 2002 | 12:23 AM
89 TA's Avatar
Car: Trans Am/Kenworth
Engine: 383/435 Cat
Transmission: T5/10 speed
Yep! I finally got tired of my car running like s@#t. So I went over to autozone and bought a new one (only $78.99) and the light went away.
Old Jan 22, 2002 | 10:13 AM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
Way Cool Jeff!
Not many of you know but that donor sticker on your license goes for car parts as well.
ECM's for $78.99 killer deal. I thought they were way more expensive.
Old Jan 22, 2002 | 06:32 PM
89 TA's Avatar
Engine: 383/435 Cat
The funny thing is that there is a $140.00 core charge.
chazman
Aug 28, 2018 03:25 PM
db057
Sep 4, 2015 07:57 AM
CORV3TT3
Aug 23, 2015 11:26 AM
chazman
Aug 22, 2015 02:01 PM
