I bought the intake and SLP runners from Allen, 1989GTATransAm years ago. He put a lot of work into it as documented on this site. Intake had to be sent to Wilson Manifolds who modified it to work with the AFR heads. Intake fresh from Wilson. AFRs are new and unused.
Sold as is, where is, with no warranties express or implied.
I've got over $5,000.00 in the intake alone. $2750.00 OBO for intake, runners and AFR heads. Wilson Manifold One of the AFR heads showing the info
Reason: Correction and addition
Here is what CARB says: If the replacement block or engine is obtained without emissions equipment, all the equipment from the original engine must be installed on the replacement block.
I am not aware of emissions equipment on a bare block but I could be wrong.
You would need to keep all the emissions related stuff from whatever car it goes into. The TPI/AFR might be the ones that need a EO# to be smog legal. Unless you put it all into an emission exempt chassis.
$4250 for the "package," includes what, intake and heads? What are you asking for the aluminum block? 2-piece rear main seal Gen 1 SBC, new/never used?
intake with runners and baseplate. Heads are bare but I have the valves, etc. to go with them. Will post the info from DNE about the heads, as well as the list of parts for the block in the next few days. Wouldn’t want to sell the block without the rotating assy, fasteners, oil pan, etc. Block ready for assy.
And here is the parts list. All parts are new, unused and, in most cases, in original packaging. The part is listed followed by the part number. Apologies, in advance, for any errors:
