Southern California Area Southern California Members.
90 deg or staight or ??? plug wires??
Old Mar 6, 2002 | 05:00 PM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
Kevin you have the L98 plug angles. What kind of plug boot do you run?
I found that a combo usually works best but nothing is sold that way unless you get the pre cut sets. I don't want to do that again. I'd rather have the opportunity to run the wires where I want.
Poll: What kind of wires do you guys like?
I currently run the GMHP wires little w/bowties on them. I'm looking at replacing them.
Old Mar 6, 2002 | 05:06 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
I always run 90s JFYI.
Old Mar 6, 2002 | 05:09 PM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
Yeah it seems like they would hug better for clearance.
Old Mar 6, 2002 | 06:42 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I have Mallory pro sidewinders on my car now, before them, I had MSD 8.5mm wires. I would recommend either. I routed mine under the headers, you can see them Saturday if I can make it down. I used 90 degree boots with both sets.
Old Mar 6, 2002 | 11:25 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Every car my dad has worked on that has MSD wires on it, he would get shocked when he touched the distributor. Also, they have a horrible resistance value per foot.
You need to get all 90º boots to work with headers.
Old Mar 7, 2002 | 10:44 AM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
Thanks guys.
Hope you can make it Jason.
eightsixseven
Dec 16, 2024 01:50 PM
Thornburg
Aug 30, 2015 08:05 AM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 19, 2015 12:07 PM
