Sponsored Vendors Connect with our Sponsored Vendors that sell the parts you need for your Third Gen Camaro or Firebird. Show your support for our vendors by offering feedback and telling friends about their services.
1984 - 1987 Chevy Camaro Speedometer Cable
Old Dec 7, 2009 | 09:36 AM
1Aauto's Avatar
Former Sponsor
1984-1987 Chevy Camaro Speedometer Cable
This speedometer cable is a new, aftermarket replacement part. It is just what you need to repair or replace a bent, broken, rusted or defective cable and get your speedometer working properly again.
Over time, many cables are susceptible to moisture and dirt penetrating through the outer casing and causing the inner transmission wire to rust or seize. This in turn may cause the wire to either snap or wear a hole in the outer casing. Also, after many years of use, the lubricant inside the casing will diminish allowing more friction to build up between the wire and casing causing failure.
1A Auto Parts Offers FREE SHIPPING On All Orders.
Old Jun 26, 2012 | 01:43 PM
1Aauto's Avatar
Former Sponsor
Re: 1984 - 1987 Chevy Camaro Speedometer Cable
ttt
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
9192camaro
16
Feb 3, 2019 12:21 AM
