Sponsored Vendors Connect with our Sponsored Vendors that sell the parts you need for your Third Gen Camaro or Firebird. Show your support for our vendors by offering feedback and telling friends about their services.
UMI New Product- Front Lower A-Arms for the 82-92 Camaro/Firebird
Old Sep 22, 2011 | 01:41 PM
UMI Performance's Avatar
Talking UMI New Product- Front Lower A-Arms for the 82-92 Camaro/Firebird
UMI Performance Front Lower A-Arms for 1982-1992 Camaro and Firebird
Part #2031
Price - $399.99 per set
UMI Performance is now offering 3rd generation Camaro and Firebird enthusiasts the opportunity to upgrade from their current factory front A-arms to UMI’s light weight and robust tubular design. Introducing UMI’s #2031 Front Lower A-Arms which are assembled with polyurethane bushings, premium ball joints, bump stops and adjustable steering stops. UMI’s A-Arm kit is shipped fully assembled and ready for a direct bolt on installation for all 82-92 F-Body models. This heavy duty design removes 5lbs of front end weight will adding tire clearance and minimizing bushing deflection. Steering radius and tire clearance for aftermarket wheels and tires can now be adjusted using the bolt on aluminum steering stop shims supplied with each A-arm kit. You will have two powder coated colors to choose from of red or black as well as a Delrin bushing upgrade. As with all UMI Performance products, the UMI#2031’s are manufactured, tested and designed in the USA (Philipsburg, PA). The #2031 A-Arms are also competitively priced at $399.99 per set.
Website Link Here
Attached Thumbnails UMI New Product- Front Lower A-Arms for the 82-92 Camaro/Firebird-2031-r-mag.jpg
Old Sep 22, 2011 | 02:28 PM
88transam 88's Avatar
Car: 1988 TransAm
Engine: sbc 9:8:1 cr 40os slugs rhs heads
Transmission: th400 3800stall b&mkit manual vb
Axle/Gears: stock
Re: UMI New Product- Front Lower A-Arms for the 82-92 Camaro/Firebird
those are pretty nice compaired to the one s they have out there for tubular k members not umi but other brands good lookin out
Old Sep 22, 2011 | 02:33 PM
Thank you and welcome to the site!
Old Sep 22, 2011 | 08:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
those are purdy....
Old Sep 25, 2011 | 04:54 PM
1Broke_camaro's Avatar
Car: 1992 Chevy Camaro
Engine: 350 TBi in the working
Transmission: 700R4 :(
i wish i could afford to bolt these right up to the new tubular k member i plan on doing next winter.....
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
