Sponsored Vendors Connect with our Sponsored Vendors that sell the parts you need for your Third Gen Camaro or Firebird. Show your support for our vendors by offering feedback and telling friends about their services.
HAWKS NEW PRODUCT!!! 84-92 T5 Adjustable Clutch Master Cylinder Kit
Old May 15, 2013 | 03:31 PM
hawksthirdgen's Avatar
Premium Sponsor
84-92 Camaro/Firebird T5 Adjustable Clutch Master Cylinder Kit
http://www.hawksthirdgenparts.com/pr...inder-Kit.html
84-95 Camaro/Firebird T-5 Adjustable Clutch Master Cylinder Kit
Since their creation, the stock clutch hydraulic system has plagued 3rd F-Bodies. Shifting quickly at high RPM is extremely hard (in some cases even impossible), especially when using a beefy aftermarket clutch. Getting into first gear or reverse sitting still is sometimes a chore! The clutch pedal sticking to the floor is all too common, as well.
Our Adjustable Master Cylinder Kit ships complete with everything needed to install, including: our custom Tilton Adjustable Master Cylinder, our Unrestricted and Heat-Wrapped Clutch Hydraulic Line, all necessary hardware, F-Body specific Billet CNC Aluminum mounting bracket for a complete firewall seal, custom hex rod with custom made fitting w/ plastic clip to attach to your factory pedal, and new hydraulic slave assembly.
This Adjustable Master Cylinder successfully flows more fluid than any other master cylinder available, makes clutch disengagement issues a thing of the past (with ANY clutch), uses a simple turnbuckle adjustment system and installs in 60-90 minutes. We also warranty these kits against failure for the entire time you own yours.
Rest assured that with our Adjustable Master Cylinder Kit installed, you'll have the quickest shifting, most reliable kit available under your left foot.
See attached pictures
Attached Thumbnails HAWKS NEW PRODUCT!!! 84-92 T5 Adjustable Clutch Master Cylinder Kit-img_9193__02365_zoom.jpg   HAWKS NEW PRODUCT!!! 84-92 T5 Adjustable Clutch Master Cylinder Kit-img_9194__23761_zoom.jpg   HAWKS NEW PRODUCT!!! 84-92 T5 Adjustable Clutch Master Cylinder Kit-img_9196__09255_zoom.jpg
Old May 15, 2013 | 03:33 PM
Premium Sponsor
Re: HAWKS NEW PRODUCT!!! 84-92 T5 Adjustable Clutch Master Cylinder Kit
Also if you do not need the slave it will be $30 off the price.
Old Sep 22, 2013 | 12:19 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
That plastic pedal stud bushing/rod retainer is a POS. If I had ordered it, I would have sent it all back, cause none of that works because of that plastic garbage.
Old Sep 23, 2013 | 06:35 AM
Premium Sponsor
Hi,
We have over 100 of these in the market with zero problems, sorry you feel that way , hope to possible help you in the future.
Thanks,
Bruce
Old Mar 14, 2017 | 10:14 AM
FormulasOnly's Avatar
Car: 1989 Formula 350
Axle/Gears: 3:23
Got it
sreZ28
Oct 22, 2015 08:21 AM
jaridjohn
Oct 5, 2015 07:01 AM
Dragonsys
Sep 25, 2015 03:51 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
R13_Braz
Sep 18, 2015 05:00 PM
