1982-1992 Chevy Camaro T-Top Weatherstrip Seal Kit (GM)
Former Sponsor
SHOP HERE 1982-1992 Chevy Camaro T-Top Weatherstrip Seal Kit (GM)
FREE SHIPPING - LIFETIME WARRANTY
This replacement weatherstrip kit includes the following pieces:
- GM T-Top Roofrail Seals: Seal the perimeter of the T-Top, and the front/rear of the side glass to the body of the car.
- GM T-Top Out Edge Seals: Seal the outer edges of the T-tops to the side glass.
- Aftermarket Door Seals: Seal the back, bottom, and front of the doors to the body of the vehicle.
- Aftermarket Hatch Seal: Seals the Hatch to the body of the vehicle.
- If your weatherstripping is causing leaks allowing damaging rain in, then this weatherstrip kit is for you. Why not replace your old, hardened, rotted seal with this new, ready to install weatherstrip set.
NOTE: Some 82-92 Camaros and Firebirds were converted to t-top cars after they left the factory by a company called Cars and Concepts (C&C). These aftermarket t-tops are not interchangeable with the stock ones and require different weatherstripping. To determine which top style you have, remove one of the tops and measure the side that tucks into the center support section of the roof. Factory, or Fisher, tops will be 30 1/4" while the C&C tops will only be 28" long. 1A Auto does NOT stock or carry the replacement C&C weatherstripping.
ALSO FITS THESE VEHICLES
VEHICLE FIT
- 1982-1992 Chevy Camaro T-Top Weatherstrip Seal Kit (GM)
- 1982-1992 Pontiac Firebird T-Top Weatherstrip Seal Kit (GM)
- 1982-1992 Pontiac Trans Am T-Top Weatherstrip Seal Kit (GM)
Re: 1982-1992 Chevy Camaro T-Top Weatherstrip Seal Kit (GM)
Hello can you tell me where I can get the 3 seals that for on the edges of the actual t top? I'm not looking for the drip edge,I'm looking for the 3 small long pieces that fit over the edges of actual glass?
VEHICLE FIT
VEHICLE FIT
Former Sponsor
Other that the drip edge we carry this seal that seals the side glass to the t-top glass
http://www.1aauto.com/1982-92-chevy-...ampaign=1ATony
1992 Trans Am
05-10-2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
NinjaNife
08-23-2015 11:49 AM
Vintageracer
08-11-2015 08:13 PM
