need opinions for school assignment
Old Apr 14, 2002 | 09:42 PM
5.7GTA's Avatar
Hi
I am doing a big research paper for my advanced composition class I need your opinions. The paper is about the best modifications for third generation camaros/firebirds. The question is what would be the best suspension mods for a camaro/firebird. Thanks for looking and responding
Old Apr 14, 2002 | 11:42 PM
mechanicalmehem's Avatar
I am going to change these things before i get my car back together. They will increase responsiveness, and allow for more adjustments/easier.
Sub-frame connectors
adjustable spherical rod end Lower trailing arms(rear)
adjustable spherical rod end Panhard bar
Strut Tower brace
tubular (Drive shaft) tunnell brace
Torque arm(aftermarket tubular)
wonder bar if it doesnt already have it(mine does--iroc)
I havent decided wether or not to do boxed/tubular(front) lower control arms or not.
I am going to change my aluminum drum rear out for a disk brake setup from a forth gen(should bolt right up other than wont have calipers yet and brake line changes) just the backing plate and stuff, not the whole rear. I will have to figure out how to work the e-brake
hmm what else........
as i remeber i will list more
Justin
Old Apr 15, 2002 | 06:17 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Re: need opinions for school assignment
Originally posted by 5.7GTA
Hi
Better have that paper identify at the very beginning just what you're trying to improve. For example, the stuff that works fine at the dragstrip is apt to leave you worse off than stock at an autocross. If you let the rest of us here know where your paper is going you'll get better help.
Norm
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
92projectcamaro
Sep 29, 2015 07:07 PM
