DO i have a 10 bolt?
Old Apr 15, 2002 | 07:27 PM
1stgenracer's Avatar
I am planning on converting my rear wheels to disk brakes and i am not sure what I have? ALso, does anyone sell a disk brake conversion kit for my car, its a 91 camaro RS. thanks
Old Apr 15, 2002 | 07:35 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Yes, your '91 has a 10 bolt. '89 was the last year for the 9 bolt.
If you really wanted to know just get under the back of your car and count the bolts on the rear end housing. That's how easy it is to tell.
Old Apr 15, 2002 | 07:48 PM
camaro6spd's Avatar
yes hence 10 bolt
Old Apr 15, 2002 | 08:37 PM
'89 IROC Vert's Avatar
My '89 has the 10-bolt.
Old Apr 15, 2002 | 08:54 PM
That's very possible. From 82-84 and '90-up, GM used 10 bolts ONLY. From '85-'89 some thirdgens had 10 bolts, some had 9 bolts. The 9 bolt was the high performance option since A. the gearing was slightly better (ie 2.73 vs 2.77, 3.23 vs 3.27, 3.42 vs 3.45) B. the 9 bolt is a stronger rear end than the 10 bolt and C. nearly all 9 bolts were disc brake rear ends. Unfortunately, after '89 Borg Warner broke off the deal with GM and quit manufacturing the 9 bolt rear ends for them. Because of this there is now only one place that sells 9 bolt parts and it's a small company that works online and is owned by one of the members here on thirdgen.org and the parts are mucho expensive compared to the 10 bolt.
Old Apr 15, 2002 | 09:34 PM
Very interesting...
Old Apr 16, 2002 | 05:43 AM
Well it was night time so i couldnt go and look at what i had under my car, thanks for the help though.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
