rear brakes that don't
Old Apr 29, 2002 | 03:12 PM
PAformula's Avatar
Has anyone tried replacing the valve plug as describing in the following b-body prop valve mod?
If so, Did it work? I had my car at the dealer today, and they told me i need new calipers. i say bulls__t! the left side is a rebuilt so I should have one side braking, right?
here is the link:
http://www.b-body.net/Technical/Brak...Mod/index.html
Feedback wanted!
Old Apr 29, 2002 | 04:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
And the magic year of your car is...? If it's an 82-88, you should really put the rear disc recall kit in, and fix it the "right" way...
Old May 1, 2002 | 01:02 PM
PAformula's Avatar
'89
I would prefer to fix it the right way, but at reasonable cost.
Old May 2, 2002 | 08:43 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
did you adjust the e brake lever? how you do this is by removing the lever from the caliper. then turn the hex stud clockwise, when looking at it from the under side, until the slack is taken up. then reinstall the lever. you may need to sand the pads down a little to get the lever back on for proper clearance. i di this on my car and now i have a firmer pedal and tighter rear brakes. to answer your question though, yes i did the proportioning valve mod. it did help a little. but that was before i did the e brake tightening. now the rear almost lock up.
Old May 3, 2002 | 07:01 AM
PAformula's Avatar
The dealer adjusted the e-brake, actually a little too tight. And the brakes do feel better but it is starting to go back to the way it was.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
