Final step!
Old Apr 30, 2002 | 11:02 AM
85wilrocu's Avatar
Final step!
Okay, I'm on the last string! I'm in the process of taking of my spindle and everything is off except where the spindle connects to the ball joint on the a-arm. Its like it rusted thru or something?
Is there a trick, special tool, what?
Thanks,
Jacob
Old Apr 30, 2002 | 12:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You need a balljoint seperator (aka pickle fork, looks like a big tuning fork or hot dog fork, but, you know, thicker! )... remove the cotter pin, and loosen the castellated nut so half of the nut is on the stud. Then put your pickle fork between the top of the balljoint and the bottom of the spindle, and give it a whack or three. The spindle will pop up, and not fall off, due to the fact that you left the nut on there. Then remove the fork, remove the nut, and remove the spindle.
To install the spindle, just tighten the castellated nut to it's torque spec, it'll seat the spindle on the balljoint.
I bought my pickle fork for $15 from Home Depot back in '96.
Old Apr 30, 2002 | 01:07 PM
85wilrocu's Avatar
Thanks tom, I'll give it a wack as soon as i get home!
Old May 1, 2002 | 01:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You're welcome. I made one mistake (I have tool cabinets on the brain); I didn't get my pickle fork from Home Depot, I bought it from Pep Boys. (Yep, finally bought a tool cabinet combo from Sears for $99, now I can move some tools off the floor!)
Gunner242
Dec 25, 2015 04:49 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
