why don't my SFC'S fit????
Old May 5, 2002 | 09:12 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
I ordered a pair of Chassis Engineering SFC"S and took them to a muffler shop where I know the guys and they were going to put them on for me for 40 bucks, good deal huh, that would have been a total of 135 bucks for installed SFC's, TOO BAD THEY DIDN'T FIT, AT ALL!!!!! ONE SIDE LOOKED LIKE IT WOULD FIT, BUT THE SIDE WITH THE CAT ONIT, NO WAY!!!
WHO HAS A CAR WITH AN H.O. MOTOR AND SFC'S, WHAT KIND DO YOU HAVE AND WHAT DID THEY COST??? bOLT ON OR WELD ONS???
Old May 6, 2002 | 11:39 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It's not uncommon to have to modify either the SFC or move the exhaust or cat a bit to get them to fit. I've also seen 4th gen SFC's accidentally shipped instead of 3rd gen ones. But that mistake is easy to recognize. If the exhaust system has been swapped or modified some fit issues will arise. Also a SFC designed for a single cat won't fit a dual cat car. You did take it to the right place (muffler shop) to get it done. Just be sure they use a drive-on style lift rather than the frame lift style. The tires must be loaded by the weight of the car and the car level. Good luck, Lon.
Old May 6, 2002 | 12:12 PM
90 Z28SS's Avatar
Well , places like chassis eng. , chassis works , Southside Machine ect. market 3rd gen subframes but more of in a general sense . And further more they really arent designed for a car with converters and stock routed exhaust . There is room left on the table to install them how you want to install them , a plus imo . While the Kenny browns , hotchkis ect. are direct fit and obviously more expensive because of that . Keep that in mind guys when subframe shopping
Old May 6, 2002 | 05:37 PM
Fast3rdGen's Avatar
my 84 T/A is was originally an HO car and i used the bolt-in Jegster sfc's from jegs and just welded them in. they are like $170 or something like that. fit perfect with an installed cat and they are tucked up nice and tight. easiest thin i ever put on my car.
Old May 6, 2002 | 06:44 PM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
Glad to hear that! I have a set of the Jegsters in my garage, just waiting for me to find the time to install them in my '83 T/A...
Rob
Old May 6, 2002 | 10:59 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
JEGSTERS???
SO THOSE BOLT-ON JEGSTERS WILL FIT NO PROBLEM?? kEEP IN MIND THAT I HAVE EDELBROCK HEADERS AND Y-PIPE, A HOLLOWED OUT 'PRODUCT FOR POWER' CAT, AND A 2 1/2 INCH FLOWMASTER PIPE.... WILL THESE STILL FIT??? i ONLY HAD FIT PROBLEMS ON THE CAT SIDE WITH THE DARN SFC HITTING AGAINST THE CAT.. THANKS GUYS...
Old May 7, 2002 | 05:07 PM
Fast3rdGen's Avatar
Re: JEGSTERS???
that is the exact same exhaust, part for part, i used to run and those sfc's fit perfect. you will have to drop the y-pipe to install the passenger side though, but that is just 4 bolts.
Jeremys87
Jul 14, 2022 09:08 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
89lsc
Aug 14, 2015 04:58 PM
Vintageracer
Aug 11, 2015 08:13 PM
