sway bar, not round, oval shapped??
Old May 7, 2002 | 09:48 PM
breathment's Avatar
I tried to measure my swaybar today, and i tried to measure it as close to the bushings as possible, but the shape was no where near round.. It was oval shaped, it was higher then it was wider.. So i couldn't get an accurate reading near the bushing.. but i measured it on the center of the bar, where it seemed to be more round shaped, and got 1.495" ~ 37mm.... im guessing i have a 36MM sway bar (GTA with WS6). but should the entire bar be round? or is it most likley round where the bushings are. or should i take it apart and double check??
Old May 7, 2002 | 09:57 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
From bushing to bushing, it should be nearly perfectly round... from bushing to end link It will be more oval-like. I don't think they got any bigger than 36mm, so you're probably right.
BTW did you use a micrometer? Sounds kinda exact...
Old May 8, 2002 | 12:38 AM
urbman's Avatar
All of them (36mm) are like that...
I have looked at 4 of them so far...
At the bushing they are oval
I measured 35.7 36.3 for four different bars
Old May 8, 2002 | 03:02 PM
breathment's Avatar
Yup..
is it actualy round where the bushings are at?
Also, is a 36mm hollow??
Old May 8, 2002 | 03:17 PM
urbman's Avatar
It is actually "oval" "where the bushings are
Old May 8, 2002 | 10:15 PM
breathment's Avatar
is there any reason for them making it oval?
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
