New to suspension, what is a idler arm?
Old May 8, 2002 | 01:22 PM
Black85TransAm's Avatar
how easy is it to replace?, also is it easy to replace lower balljoints?????
Old May 8, 2002 | 01:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It's the arm that connects the passenger side of the centerlink to the front of the frame. It basically follows the pitman arm (from the steering box), to keep the center link moving in a straight line. Since it's not powered, it "idles". You'd remove the cotter pin from the castellated nut, separate the two with a pickle fork. Then, mark the location of the idler arm on the frame, and remove the arm. Put the new arm in at the same height the old arm was at, connect it to the center link, tighten the castellated nut down to join the joints, and insert a new cotter pin.
Can't describe the balljoint replacement; haven't done that yet.
The Haynes 82-92 Firebird manual (Pep Boys) shows photographs of the front suspension, and tells you how to replace each piece.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
