I think I have coil-overs....
When I was switching out my rims today, I noticed that the rear shocks had a spring on the outside of them, wrapped around them. Are these coil-overs? What is the difference between them and regular shocks? Better or worse? They were either blue with yellow springs, or yellow with blue springs...don't exactly remember at the moment.
Car: 82 camaro SC
Those sound like the old overload shocks--the springs adds a little height and stability if the rear is sagging. If they are coil-overs, you won't have the normal coil spring in the rear. Do you have the regular springs--I'm guessing you do. The shocks you have a probably just a band-aid for worn springs.
