SSBC Front brake upgrade kit?
Car: 86' Z28
Engine: 355
Has anybody tried SSBC's brake upgrade kit available through Year one? My right front rotor is totally shot and i'm not wanting to go with stock replacements again, but i have no money for a complete brake system. At 250 bucks this kit comes with cross drilled rotors, pads and harware. Seems like a good deal to me, but is it worth my time?
Eric
Eric
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Honestly, I think Year One is WAY overpriced. If you shop around you can probably find what you need for less $$$
If you still decide to stick with Y1 then you will not be dissappointed. The kit comes with everything you need. I swapped all the parts and repacked the bearings in less than 2 hours.
The only upgrade is that the rotors are slotted.
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
The Woldwide Camaro Assoc has a sale on brake upgrades this month. Check it out
If you have ever worked on disc brakes before, its a snap.
If you haven't done this before, its pretty straight forward:
Jack up and secure the car
Remove the wheel
Remove the caliper retaining bolts, move and secure the caliper
Use a screwdriver to pry open the bearing cap
Remove the nut, washers, and bearings
Remove the bearing seals off the old rotor. Replace them if they are worn.
Swap rotors
Inspeect, clean, and repack the bearings
Reassembly is the reverse.
Not really any tips involved. Just expect to get your hands really greasy.
Remove the wheel
Swap rotors
The only muscle needed is to loosen and torque the bolts that are involved.
Terrell351
Jun 13, 2021 01:13 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
