ID'ing HOLLOW FT SWAY BAR?
Old May 11, 2002 | 04:39 PM
Saywhut's Avatar
How can you tell ?
I pulled one off a 87 IROC, 5.0 TPI, it measures 1 11/32", feels too light to be solid, tho I can't weigh it.
The ends do seem to have a parting line, as if a tube had been pressed together, but I'm thinking this could also be from the shear used to cut a solid rod.
Are there any other visual clues?
Old May 11, 2002 | 04:48 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I believe there's supposed to be a drain hole (somewhere near the end link I think) on the hollow ones. It's probably covered up with dirt.
If it feels light, it's gotta be hollow. I pulled the solid one off my 82 Z28, it was really heavy.
The one I pulled off a 87 GTA was hollow and a LOT lighter. It measured 1 7/16" at the middle. (36mm??)
Old May 11, 2002 | 05:08 PM
Saywhut's Avatar
Thanks, i found the holes I'd missed, probed them with a scribe, it's definately hollow.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
