i was wondering what the length of the sway bar. the length that i have is 44 inches eyelit to eyelit. im asking because i broke one of my end links and when i went to install two new ones they didnt want to fit. my end links were not straight up and down they were tilted in like i have a bent sway bar. any information would be helpful.
I don't have a length to give you and I'm not about to run out and measure but if the links didn't line up then its probably because the suspension was extended (as the wheels drop when the car is lifted). The lower they go, the more difficult the links will be to install. If you can't do anything about the wheel drop then have the car up on jackstands, unbolt the center braces that hold the bar on but keep it in place with a jack. Then try to line up the end links. Hope that helps.
