ok my outside bearing went on my 87 gta and i took the thing apart and when i got to the bearing it was stuck on the spindle. I tried to use a puller on it hoping it might let loose but no such luck just wondering if anyone had any tricks. Thanks
Lets see ...
You have the hub off ?
So the inner (closest to the spindle) bearing is stuck ?
and while pulling the hub you left the rear seal behind ?
Is this what we are working on ?
