Installing SFC's
Old May 29, 2002 | 05:12 PM
Brian'sIROC's Avatar
Installing SFC's
Where did everyone get their SFC's installed? A body shop? Muffler shop? How much did it cost? I was quoted $260. Thats how much they cost! Also which brand do you recommend?
Old May 29, 2002 | 05:56 PM
ede's Avatar
ede
i made mine and did the install, it shouldn't take over 2 hours labor to do it, excluding any exhaust work. as for buying a set i'd look at spohns SFCs
Old May 29, 2002 | 09:04 PM
goneracin's Avatar
Spohns look great, except as of tonites webpage, he is not producing. maybe its not updated yet or????
Old Jun 2, 2002 | 11:08 AM
82Trans Man's Avatar
Ede how hard is it to make your own? Do you weld in SFC's to the pinch weld or periodically down the floor boards? TIA James
Old Jun 2, 2002 | 01:37 PM
vjo90RS8's Avatar
Car: 2002 Z28
I had mine dont at a muffler shop for $120.
Spohn is not accepting orders for SFC because he is currently in the process of switching from boxed to tubular SFCs, he should be releasing them very shortly, "we think"
Old Jun 2, 2002 | 04:15 PM
ede's Avatar
ede
i made a double set and welded the outter tube to the floor pan, bottom lip of the rocker panel, and the factory sub frames. they aren't hard to make
Old Jun 4, 2002 | 07:13 AM
thanks do you have any pictures also. Thanks Again James
Old Jun 4, 2002 | 10:46 PM
91FormulaCRAZY's Avatar
Which are the better design though? The box or tubular subframes? Also, which one, Tubular, or boxed, is good to use as extra jacking points? Thanks.
Old Jun 5, 2002 | 01:12 PM
Momar's Avatar
That has been debated. Tubular are lighter. The boxed would make better jacking points. Tubular are supposed to have more torsional strength but in my mind I think that the torsional strength is not what would be needed the most. I would think that boxed would cause less flexing up and down in the middle. I dont know, but I wish spohn would get his conversion done because I am going to go with his even though I kind of wonder if it would be better to stay with boxed because he seems to make real good products and is always on here to help out if we have questions.
Ben
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
kairles
Oct 26, 2015 09:13 PM
gixxer92
Sep 1, 2015 04:32 PM
