Front spring isolation pads
Old May 30, 2002 | 08:24 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Well, after much blood sweat and tears I installed one side of the front suspension. Now I can't find the other isolation pad! Will the ride height be all that bad if I put a new one in and keep the old one in the other side? I am sure it will crush down like these were when I took them out but I don't know how long it will take. I know I probalbly should change the one that is already in there but... I don't wanna!!
Old May 30, 2002 | 09:07 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
it won't tooo noticable.
It's not as if they were removed all together.
Old May 30, 2002 | 11:30 AM
urbman's Avatar
leaving the isolators out will make things a bit noisier.
High frequency vibration will pass to the K-member
without damping.
For incentive... (not a flame)
The reason you do things yourself is to do things "right".
"one in one lost" you might as well have pep boys do it
scratch the paint, fail to index the springs, tighten
one a arm in the air, the other on the ground and you
have "f*** up" written all over the car
Old May 30, 2002 | 12:01 PM
Omega's Avatar
Engine: LS1 / LS3
I ordered 2 today.. if it sits really badly then I will swap the old one out.
Pep Boys.. don't get me started.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
TA8487
Aug 11, 2015 09:02 PM
