Line Lock Install
Old Jun 10, 2002 | 11:36 AM
Chris90Formula's Avatar
Line Lock Install
I'm installing a Hurst Roll Control and obviously the metric brake line fittings are giving me problems. I believe that they are M10 x 1.5 thread. I've searched some of the other posts which say to go to PepBoys or Autozone for the adapter fittings. I went to both and couldn't find them. I did find a piece of brake line that has the iso flares on the ends. My plan is to cut of the ends of the brake lines (the two lines that are coming from the front brakes and go to the dist. block). Then use standard fittings and double flare the ends. Then these lines will connect to the 3/16 adapter in the soleniod. The only problem that I see is that I won't be able to flare the lines in the car because the flaring tool is too big and difficult to hold when turning it. How hard is it to remove the brake lines? I'm sure that the driver side line is pretty easy, but how about the passenger side line? Any other ideas or solutions are appreciated.
Thanks,
Chris
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
I'llrocya
Feb 2, 2016 11:43 PM
