1 in raise???????
Old Jun 10, 2002 | 09:20 PM
Vortec350's Avatar
1 in raise???????
I've got a question, Somebody was trying to tell me that on the third gen body styles, you get better handling if you raise it an inch instead of dropping it. Comments and suggestions about this would be much appreciated.
Old Jun 11, 2002 | 08:14 AM
ATOMonkey's Avatar
The only thing I can think of is for drag racing. Raising 1" makes a longer moment arm for weight transfer and also raises the instant center. The result is more traction. I wouldn't think it would help cornering unless the increased ride height changed the suspension geometry enough to compensate for the higher center of mass.
Old Jun 11, 2002 | 08:23 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
Usually just leaving it is best.
It's the 'roll center height' that you must be concerned with when engineering a car, any car, to corner better. It is a measurement taken that triangulates the A arms. spindle pivots and one other calculation that eludes me at this moment. Once measured, you find your roll height.
If the car is too low, that calculated point, much like a center of gravity, is actually below the pavement surface. Not real good.
Old Jun 11, 2002 | 09:23 PM
Vortec350's Avatar
So alot of you guys out there with thirdgens drop your camaros an inch to get better handling?
88SS6SPEED
Nov 11, 2015 07:05 AM
roysatikas
Sep 22, 2015 08:15 PM
camaronils
Sep 20, 2015 02:57 PM
