Allignment ?
Old Jun 13, 2002 | 01:19 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
Allignment ?
I just had the front end suspension re-built and got bigger wheels as well, I want to get the RS alligned but I wanted to ask first if the front end alignment setting is the same for 16" wheels and 17" wheels? My Rs is stock height w/ 17 X 8 IROC wheels. Would this be the correct setting:
Caster = L +4 R +4.5
Camber = L -.5 R -.5
Toe (in) = 3/32
Old Jun 13, 2002 | 02:51 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Wheel size shouldn't make a difference.
Old Jun 13, 2002 | 02:57 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Thanks Bret!
Old Jun 13, 2002 | 05:47 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
wheel size makes no difference. but overall tire diameter does. the taller a tire the less toe in needed. in the overall scheme of things, the original tire size is 25.7" diameter. you can go about 1" taller/shorter and won't need to change toe any. the specs that you posted are fine to use.
Old Jun 14, 2002 | 09:54 AM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Mrr23 - Thank You!
Old Jun 14, 2002 | 06:17 PM
mrr23's Avatar
Engine: 360 HSR
anytime.
88KARRV6
Dec 4, 2006 09:16 PM
shr00m
May 31, 2005 01:11 AM
89Iroc-ZL98
Jun 4, 2002 02:00 PM
Js92RS
Southern California Area
Apr 15, 2002 05:31 PM
