Loose steering - what to replace next?
Old Jun 19, 2002 | 08:08 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Over the winter I replaced both inner and outer tie rods, idler arm, and center link. However I still have alot of play in the steering wheel. Id' say the wheel can go a good 2-3 inches without getting response from the car. What's next?? Is there somethnig inside the column that can be worn out, or do I need to replace the steering box?
With 17's and fat wheels the car gets pulled around enough, not being able to respond to the quick movement gets kinda unnerving.
Old Jun 19, 2002 | 08:40 PM
PonchoTA's Avatar
Try the rag joint! I replaced the entire front suspension system, but was still unhappy with the response from the steering wheel. I replaced the rag joint and now it feels really tight. Made a world of difference! Of course, mine's an '83, and EVERYTHING was worn out on it!!
hth
Old Jun 20, 2002 | 09:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'd say your steering box is worn out if you've replaced all the linkage.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
