Brakes WTF?
Old Jun 20, 2002 | 03:11 PM
9225th's Avatar
Brakes WTF?
I just found out about this website, I wish I knew about it sooner. The problem I am having is my brakes Suck! I have an unaltered 92 Z-28 58,000 original miles. It has four wheel discs, cast iron front calipers, and the PBR rear calipers. I have changed the master cylinder, front and rear pads with carbon metallics, resurfaced all rotors. I have inspected all the brake lines for cracking, and flushed and bled the system 4 times. It seems the rear brakes are not working like they should. I can jack up the car put it in gear and let the rear wheels turn. I leg press the brake pedal, and the rear wheels just keep on turning. If I apply the parking brake, and push on the brake pedal at the same time the wheels finally stop. My brakes seem to work a little better after I warm them up. What do you think the problem could be? Sorry for such a long post, but this problem is starting to **** me off! PS there is no way to adjust the parking brake cable.
Old Jun 20, 2002 | 03:24 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Welcome!
How does it stop during normal everyday driving? A lot of us experience those symptoms but to be honest there isn't really a cure. The rear PBR calipers can be adjusted. Pick up a GM manual for your year and model for info on how to do it (Highly recomended to have anyway)
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
First off, welcome to the site, where you will be spending all of your free time. Second, yes you can adjust your e-brake. I can't remember all the instructions, but try the search feature on the site. It's a great tool.
After all the work you did, I have no idea what the problem could be...maybe vacuum booster?
Ed
Old Jun 20, 2002 | 03:33 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I have a question. How often do you use your parking brake?
It is a MUST that you ALWAYS use the parking brake to keep the rear calipers working properly and to keep them adjusted.
Once I got in the habit of setting the parking brake, my rear brakes stared operating better. I actually wear the pads out now.
Old Jun 20, 2002 | 05:07 PM
9225th's Avatar
Thanks for the inputs. I never use my parking brake. I guess I should go out and cycle it a few times. It just might help.
Thanks again!
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Sep 19, 2015 08:13 PM
DARKmj16
Sep 9, 2015 04:07 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
