would this cause my car to pull?
Old Jun 21, 2002 | 11:07 PM
87 B4Z's Avatar
i recently just did my front brakes on my car. i replaced the calipers, hoses, pads, and rotors, and my car still pulls to the right while braking, i looked at my rear brakes and the driver said wheel cylinder is leaking fluid. will that cause my car to pull?
Old Jun 22, 2002 | 01:14 AM
AFrikinGoodTime's Avatar
If the caliper is leaking, it very well cold be seized or low on pressure causing it not to fuction as well. if this happens, the other side of the car will slow down faster causing it to pull that side.
Its just like running straight and then grabbing onto a pole with only one arm. It will yank you to that side. ( I know this is a dramatic example but it gets the point across ).
Old Jun 22, 2002 | 09:06 AM
87 B4Z's Avatar
the front are fine, it is the rear wheel cylinder that has a leak.
Old Jun 23, 2002 | 11:59 AM
mechanicalmehem's Avatar
yes, because you are braking in the right rear and not the left rear. and thus a pull
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
