help-still very poor brakes
Old Jun 25, 2002 | 03:48 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
just replaced my master cylinder today and the brakes are still very poor, they need to be slammed all the way down and still only slowly stop. Also when the car is off, pressure never fully builds up, whats else could be wrong? Im guessing power booster or proportioning valve. Help please.
info on car- 1984 l69 trans am, 700r-4 and rear discs/3.73's
110k on car
Old Jun 25, 2002 | 04:44 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
Sometimes depending on the crankshaft u got in your car.
If its a big time performance crankshaft it takes away brake power.
But I dont think thats your problem, but ive heard about this.
Old Jun 25, 2002 | 05:00 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
the 305 is still stock and its perfomance camshafts that will rob your vacuum, any other ideas? Anyone?
Old Jun 26, 2002 | 11:04 AM
urbman's Avatar
Well...
First things first
1. Make sure the calipers are assembled correctly
- The pins should be clean straight smooth and lubed
- the o rings need to be fresh (and lubed)
- There needs tobe at least .005 in clearance
between the spindle ears and the caliper itself
2. The brake fluid should look like a pilsner not a stout
( like miller light not like guiness )
3. Bleeding
This is what I think may be the problem.
I am a "true believer" with respect to power bleeding.
My suggestion is that it is difficult to adequately gravity
bleed an assembled system. I would either get one of
the power bleeding tools (phoenix, mity vac or some such)
or take it to someone that has one.
Old Jun 26, 2002 | 02:01 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Sounds like your brake booster is failing. When you first get in the car is there any reserve? The breake pedal should operate about 2 or 3 times with assist without the engine running. If the pedal is stiff the booster needs to be replaced.
Old Jun 27, 2002 | 06:16 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Here is a simple test you can perform to test your brake booster function.
1) With the engine off. Pump the brake pedal several 5 or 6 times.
2) Hold the brake pedal on the floor.
3) Start the engine.
4) If the brake booster is working properly the pedal should move slightly closed to the floor.
The newest of our cars is already over 10 years old. So replaceing the brake booster and master cylinder is cheap insurance.
Thanx,ANDYZ28
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
