Rear disk rotor removal
Old Jul 16, 2002 | 08:55 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
How do you remove the rotor from a 9 bolt '88 posi rear? I already have the calipers off. The instructions from my Chiltons manual tells me to simply pull the rotors off from the axle. These things will not budge. I wanted to check in with you folks before taking a light sledge to it.
Thanks,
GC
Old Jul 17, 2002 | 06:54 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The rotors are probably "frozen" to the axles by a little rust. Take a 2x4 and knock the hell out of it with a hammer and they should come loose enought to pull them off. During reinstallation, put some anti-sieze on the back of the rotor and the axle flange to keep this from happening again.
Ed
Old Jul 17, 2002 | 11:43 AM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
Unlike the front rotors, I can't see a center cap that would hold a greased nut to retain the rotor.
I'll pound some hell into it then back out again and see what happens.
Old Jul 17, 2002 | 03:05 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Squirt a little WD-40 around the base of the wheel studs and let it soak in for a few minutes. Then LIGHLTY tap the rotors, preferably with a rubber mallot. They should come loose.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
