hey guys,
i have a question for u guys. when i drive my car down the road and i hit a bump or sewer plate, something in the passenger side front tire jiggles . and when i take a turn , my passenger side back tire makes a grinding noise. i took the back tire off and and then put it back on, it seemed like one of the bolts for the nuts was a little bit shorter. when i push on the side of my , it makes a noise like two things are coming together. well i hope u guys help me out. thanx alot
"jiggles": like in a sorority house movie or something?
Seriously... if you meant to say "jingles", like coins in your pocket, it's your stabilizer bar end-links.
The scraping sound from your right rear tire is probably the tire rubbing on either the fender or the inside of the fender well. Worn-out Panhard bar bushings, or a bent bar, will allow the rear to move from side to side under the car. That's what I'd look at firstl.
thanx man for relpying to my topic and im sorry for the spelling, lol. well how do i fix both of these problems and where are these problem areas located at or near. thanx man for your help
somebody please help me out
get a good shop manual like a helms... The components as well as removal of them will be detailed in there.
if your gonna be working on the panhards. You migh as well replace those cheap stamped metal ones with good aftermarkets. Meaning to do the same myself but im short on cash.
