Wont Stop
Old Jul 23, 2002 | 02:36 AM
Camero90tbiRS's Avatar
Wont Stop
OK HERES MY PROBLEM. MY BRAKES STARTED TO GET VERY HARD TO PUSH DOWN AND STOP. I CHANGED THE PADS AND BLEEDED THE BRAKES. THEY WORK GOOD FOR 2 DAYS AND THEN COMPLETELY STOPED WORKING. THEY JUST WONT PUSH DOWN. THEY STILL HISS SO IM GUESSING ITS NOT THE MASTER CYLINDER BUT I NEED TO KNOW WHAT ELSE IT COULD BE. COULD I HAVE TO DO A BETTER JOB OF BLEEDING THEM?
Old Jul 23, 2002 | 07:48 AM
does anyone know what can be wrong?
Old Jul 24, 2002 | 10:44 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
did you check your brake booster? Thats probably bad and causing the hard peddle. Its taht big black cyl behind the master cyl. Check teh vacuum connection too. Low engoen vacuum will also cause this (real low). Not to be picky but dont type in all caps. Looks like your shouting.
Old Jul 25, 2002 | 12:53 PM
Momar's Avatar
I think your shift key was stuck.
Actually I think it kind of sounds like the break booster also.
Ben
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
