leaning
Old Jul 29, 2002 | 08:39 PM
pitpens's Avatar
leaning
My 1984 Camaro leans to the passenger side real bad, the springs and shocks all look good. what else could be the problem.
Old Jul 30, 2002 | 03:16 AM
madmanups's Avatar
This sounds stupid but did you check if the tires all are equally aired? Mine does it too but that helped a little, also when I put new struts and springs, it helped some. Still does it a little. I looked at the back of my car and saw that I'm missing a bushing completely! I think that might be the problem. Good luck.
Old Jul 30, 2002 | 09:47 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
The springs might look good (as in not broken) but they could be shot. Try replacing the rear springs first (since they are the easiest) I bet it will help. Springs lose their strength over time.
Old Jul 30, 2002 | 01:51 PM
nitrobreth's Avatar
do a search for "car leans" or something like that. had a huge topic with pics a while back.
Old Aug 2, 2002 | 05:02 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
leans to the passenger side real bad........ what else could be the problem?
Lose the fat chick...
Couldn't resist.
Check your spring isolators too.
Ed
Old Aug 2, 2002 | 09:18 AM
urbman's Avatar
Let the fat chick drive
Should be pretty even...
F-body-fan
Jan 12, 2023 01:49 PM
db057
Jan 10, 2020 08:55 PM
Elephantismo
Feb 13, 2019 12:51 AM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
