Aftermarket 12 Bolt question within . . .
Old Jul 30, 2002 | 11:10 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I was thinking about getting a Moser 12 Bolt for use in the project car and had a couple of questions. (Just in case it may matter, my car will not be used for drag racing; it'll be mostly street and occasional autox.) For one, their housing has larger tubes than our stock rears and our factory sway bar mounts will probably not fit the tubes. I was wondering how adapting the mounts or using aftermarket sway bar adaptors will affect the rear geometry if at all. As far as I can tell, I don't think it will cause any undesired effects or problems with the handling of the car, but I thought I'd ask the experts here.
Old Jul 31, 2002 | 08:26 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
When I called Moser on this about my 12 bolt they told me to use 3" exhaust clamps to bolt the sway bar mounts on and done.Rear isn't in yet,but I have it built in the garage with another sway bar mounted as they said with no problems.
Old Jul 31, 2002 | 09:58 AM
ATOMonkey's Avatar
Isn't a 12 bolt a little overkill for autox? I'd think you could find a 9 bolt or get your 10 redone for less and it'd be a lighter rear.
Old Jul 31, 2002 | 10:13 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
SPOHN
Spohn makes mounts for the aftermarket 12 bolt:
http://www.spohn.net/index.cfm?fusea...t&productid=32
Old Jul 31, 2002 | 09:47 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
ATOMonkey, the car will be run on an autox course for fun, not competition. It will be mainly my toy/weekend/street/show car and it will be putting out a lot of power. I figured that I should just go with a rear that will be able to handle the power and not worry about it.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
