what mods for traction besides slicks...
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
the only thing i would add is relocation brackets, i would also say a good panhard rod and good sub-frame connectors help as well..
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Any good aftermarket suspension will be an improvement from the factory setup.
Make sure the SFC are weld-in not bolt-in. Some aftermarket LCA and some relocation brackets are next. A better torque arm so it won't flex and you can adjust the pinion angle.
Don't forget about the air bags inside the rear springs. They're also a tuning aid that can help traction.
There are no real "traction bars" available for a third gen because of how the suspension is set up. Just change it all to aftermarket parts and it'll work fine.
Numbah-1
Sep 12, 2015 08:57 PM
