e-brake modifications or substitutes?
Old Aug 5, 2002 | 08:40 AM
ERIC'86IROC's Avatar
Is there any aftermarket rear brake systems or other options to get a simpler, smaller e-brake setup? Mine has never worked. I just rebuild the rear end and when taking the brakes off I found that everything was seized and rusted. My rear brakes work fine though. What are the options other than rebuild the stock system?
Old Aug 5, 2002 | 10:54 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
PonchoTA recently converted his old style rear disc brakes over to the more desirable '89-'92 style rear disc brakes.
It is a popular conversion.
Thanx,ANDYZ28
Old Aug 5, 2002 | 09:31 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You could also upgrade to the LS1 internal drum style, also called the Explorer type. They have a drum brake on the inside of the rotor. Cool setup.
I just put an '89 rear with the '89 brake setup in my '88 Iroc, probably the simplest to do. Works great.
Ed
Old Aug 8, 2002 | 11:43 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes, the LS1 rotor e-brake is the hot ticket. It has a small internal drum brake that is used for the e-brake only.
Lon
Old Aug 8, 2002 | 11:58 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
do the 89-92 rear disks lock up if you pull the ebrake? cause I'd like to have rear disks again but if they dont lock up then I dont want them. And imma have to stick with drum brakes.
Old Aug 9, 2002 | 02:41 AM
ebmiller88's Avatar
I haven't yanked on my brake hard enough to lock them up yet. I really don't think I need to. As long as they hold, which they do, they're fine.
I just found the LS1 brake setup online for $200 complete. Not too shabby IMO.
Ed
Old Aug 9, 2002 | 06:25 AM
Thanks for the help fellas. I wasn't aware of the LS1 style differences. Sounds interesting.
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
88transam5.0
Dec 19, 2001 06:58 PM
Blown_n_Injected
Aug 23, 2001 03:48 PM
Blown_n_Injected
Aug 18, 2001 06:30 PM
