replacing power steering seals, how do I do it?
Old Aug 22, 2002 | 04:45 PM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
The bottom of the drive shaft (steering wise) has a seal which is leaking very bad. I can't get inspection with the leak so I have to replace the seal. Any sugestions of what I need to do. I have a 350 with a/c. I haven't even tried yet, but I just wanted to know some opinions on what all kind of work is needed to be done.
Oh yeah, when I had the car on a lift, I looked at the nut for the pitman arm. It was so loose I could turn it by hand. I could have lost steering and died. pretty crazy.
Old Aug 22, 2002 | 06:33 PM
ede's Avatar
ede
for around 125 dollars you can get a rebuilt box, it's a lot easy to swap them out than trying to find seals from gm and doing all that work.
Old Aug 23, 2002 | 02:42 AM
I already bought the seals. $14 for the overhaul kit. I will work on it tomorrow morning. I still might need some experienced advice though.
Old Aug 23, 2002 | 06:54 AM
ede's Avatar
ede
ok then since you want to take it apart, the first problem i ran into was holding the box, ended up using lag screws and bolting it to my bench. then i needed a socket 1 5/16ths i think. pay attention to any vee seals, if any, and the direction they're installed.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
Reborn756
Sep 4, 2015 03:42 AM
