clunking, popping, when going in reverse
Old Aug 25, 2002 | 10:00 PM
primer84z's Avatar
right as i disengage the clutch and start rolling backwards i hear a clunking noise. could this be the struts need to be replaced? sometimes when i stop i hear it too. not on take off though. i figured that when the weight transfers down on the front end it causes the struts to make that noise because they are old. is this a common symptom off bad struts? my ball joints are going out too becuase when i cut the wheel real hard at low speeds it wobbles and pops.
Old Aug 26, 2002 | 09:21 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'd check your ball joints and tie rods first, then tranny mount. If these are worn bad, you'll get all kinds of noise.
Ed
Old Aug 26, 2002 | 07:55 PM
primer84z's Avatar
thanks alot. i replaced the trans mount last summer so i know thats not it becuase its not the tranny hitting the floor pan. im going to take it up to midas and get basically the whole front end rebuilt. hope its not to pricey.
Old Aug 26, 2002 | 10:32 PM
87350IROC's Avatar
Car: 87' IROC
Is the tranny mount the rubber bushing thing on top of the back of the trans?
Old Aug 27, 2002 | 08:57 AM
Desert86Roc's Avatar
Check all your crossmember to frame bolts. I have seen these work loose causing it to shift back and forth making a "clunk" noise when braking in reverse. You should be able to tell if the washer/bolt head has been moving.
Also, check your top strut mounts by removing the plastic cap and shining a flashlight into the cup. If the rubber looks cracked or broken, the mount is bad and may be shifting enough for metal to hit metal.
Old Sep 3, 2002 | 03:04 PM
johnnyformula's Avatar
if all else fails, check your driveshaft u-joints
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
RS Reaper
Sep 27, 2015 07:04 PM
Lmancha96
Sep 25, 2015 08:11 PM
