ball joint replacement
Old Sep 13, 2002 | 06:31 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
http://www.fl-thirdgen.org/balljointreplacement.html
here's how i do it.
Old Sep 14, 2002 | 07:04 AM
ede's Avatar
ede
long as it works for you, but i've seen several people not able to get the greese fitting in after trying it without a press. considering you can get free loaner tool lots of places any more or buy one reasonably i'll stick with a press. not to mention nothing is supporting the car after you lift it with the bottle jack. i worry too much about dropping cars and more especially dropping a car on me.
Old Sep 14, 2002 | 05:48 PM
mrr23's Avatar
Engine: 360 HSR
i should have clarified the placement of the bottle jack clearer. do not put it where the grease fitting goes. place it on the edge of the ball joint. good point there.
as far as the supporting of the car after jacking up on the control arm. come up off the original support jack or other support device you had under the control arm. about 1-2 inches. there are 2 jacks being used here. as you hammer on the control arm, the car lowers back onto the original support jack or other support device. so no problem with the car falling off anything.
Old Sep 14, 2002 | 06:17 PM
Eightyninef's Avatar
MMR, the boot has a direction on it because it has a notch in it. The notch is so the grease leaks out towards the spring and not towards the brake rotor.
not that the grease ozes out in any 1 direction anyway, but that is the design.
BTW, I think I will stay with pressing them in. I can picture you damaging the LCA with the BFH. but pressing them ain't no picnik either.
Larry
Old Sep 14, 2002 | 06:21 PM
mrr23's Avatar
Engine: 360 HSR
Larry
well show me the picture on how i would damage the control arm.
Old Sep 14, 2002 | 06:45 PM
ede's Avatar
ede
i've saw lot of people beat the hell out of the control arm and or ball joint and only the ball joint was damaged. mostly the greese fitting didn't go in.
Old Sep 14, 2002 | 06:48 PM
mrr23's Avatar
Engine: 360 HSR
another way to do it would be to put a socket about the same diameter as the ball joint so as not to damage the area where the zerk fitting goes.
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
g.l.mos
Aug 22, 2015 12:02 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
MENINBLK
Aug 5, 2015 11:58 PM
NBrehm
Aug 5, 2015 07:57 PM
